*&#^$% Loctite
Old Aug 25, 2007 | 06:18 PM
alpe320's Avatar
1999 E320
Angry *&#^$% Loctite
Looking for helpful hints. '99 E320 and I'm trying to remove the lower bolts from the sway bar links (to replace links/bushings). Tried everything I know of to break these loose. Ideas?
Old Aug 25, 2007 | 06:23 PM
raymond g-'s Avatar
99 E320
i believe i saw blue on them, so if Loctite blue used, just a little bit of heat should soften it and allow for removal. i was able to remove the fitting w/o
resorting to heat. i used torx bit on ratchet.
Old Aug 27, 2007 | 03:12 PM
E420SportGT's Avatar
'97 MB E420 Sport/'88 MR2
try spraying and letting them soak with PB Blaster.
Old Aug 27, 2007 | 03:51 PM
alpe320's Avatar
1999 E320
Thanks. I'll give your suggestions a try.
