K&N users
Old Sep 6, 2007 | 08:14 PM
43fatman's Avatar
2001 E430 Sport
K&N users
Ok so I have had my 210 for 4 or so months the first thing i did was change the oil and put a K&N in. I noticed mine needs cleaning. How often do you clean yours? Is it normal to clean them often? I had a open one in my 4Runner and did not have to clean it that often. By the way i live in Atlanta and drive 72miles round trip to work.
Old Sep 6, 2007 | 08:36 PM
Quadcammer's Avatar
96 and 08 911 turbos
Can I make a suggestion?
put the k&n in the trash, and use a stock paper filter.
here are the reasons:
1. It filters much better
2. You don't have oil possibly getting all over the maf. This is especially prevalent upon re-oiling.
3. The power difference is not noticeable.
4. paper filters are about $15, and you don't have to worry about cleaning, oiling, etc.
Old Sep 6, 2007 | 09:37 PM
43fatman's Avatar
2001 E430 Sport
Hell thats why i made the post. So how long did you have yours in? I am thinking of going back to stock. Do you also find crap trapped under the filter in the box?
Old Sep 7, 2007 | 10:17 AM
Quadcammer's Avatar
I have not used a K&N in my MB because of the above reasons. I found a lot of crap under the filter when I bought the car. I cleaned it all out, and I've driven about 5k miles since then. I've checked the airbox and so far its been pretty clean.
I have a lot of experience with K&Ns in other cars and the higher silica level indicates a less completely filtering. If I didn't have any other choice on my mustang, I would run a paper filter on that as well.
Old Sep 7, 2007 | 10:24 AM
amgqmp1's Avatar
'97 E320
Oliverk,
Thanks for the feedback...I won't even consider a K&N for my E320 now.
You just saved me some money...and I'm sure the anger of cleaning the MAF down the road...
Old Sep 7, 2007 | 10:51 AM
Quadcammer's Avatar
sure.
I've cleaned and reoiled probably 20 or 25 K&Ns and I still over oil. The spray oil is not the easiest thing to control.
One thing I've found that helps to reduce the chances of a contaminated MAF, is to wrap the new, or freshly oiled k&N in newspaper for a few hours to soak up some of the oil.
Its really a catch-22. They need a good amount of oil to filter properly, but if you put too much on, you screw up the maf.
