Most of them eventually do this. The fuel sending unit needs to be replaced. However, if you can live with it, save a few hundred bucks. If the fluctuation is not dramatic, you can use the trip odometer at each fill-up to know exactly what you have left.
Quick question... Is the fuel sending unit the same from a wagon?
I need to replace one in a 96 e320 sedan and we have a parts e320 wagon outside. Any help is appreciated
raymond g-
close
- Join DateJan 2004
- LocationSeattle WA
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive99 E320
Liked:178 Times in 161 Posts
i have an interchange manual but wont be able to check until this evening.
note, however, that the sedan has vertical tank and wagon has horiz.
you can also scan the parts diagrams. free use of MB if you're in NA.
russian is free web access
https://epc.startekinfo.com/epc/home.jsp
http://www.detali.ru/cat/oem_mb.asp
