Can you please help me!!!!!!!!!!!
Old Dec 26, 2007 | 04:18 PM
taylor210's Avatar
02 E320 Blk, 09 E350 Blk
I'm trying to clean the inner wall of my wheels, I've unbolt the 5 lugs and somehow I can not take the wheels off of my car. I mean all 4 wheels....
I've even spary wd-40 and still won't come off. Btw, I've got 17 sports wheels...
Is there any smart ways to take the wheels off???
Thanks in advance:
Old Dec 26, 2007 | 04:47 PM
ProV1's Avatar
MB, BMW
grow some muscles dude...
seriously, go get a 2x4 or a baseball bat and swing away. kicking also works. make sure to hit the tire only, u dont wanna f##k up the wheel or the body!!
Old Dec 26, 2007 | 04:48 PM
124-Fan's Avatar
Mercedes Benz
Get a 750 gr. sledge hammer, or something equivalent and strike the inside rim of the wheel outwards ( and not the tire itself ) while it is off the ground, using the correct force of course... Turn the wheel and don´t strike repeatedly at the same spot.. It will come off that way.. - been there, done that..
Cheers,
Old Dec 26, 2007 | 04:57 PM
lkchris's Avatar
'10 CL550, '12 GL550
Wheel is corroded to the hub.
When reinstalling, use some antiseize compound.
Old Dec 26, 2007 | 06:50 PM
Quadcammer's Avatar
96 and 08 911 turbos
couple of good kicks usually does it for me.
DO NOT DO THIS IF THE CAR IS ON A JACK ONLY!
Old Dec 27, 2007 | 08:43 AM
E-Klasse's Avatar
W205 C300
Jack the car up off of the ground.
Old Dec 27, 2007 | 09:22 AM
72chevy4x4's Avatar
I think Oliver's trying to say put blocks or jackstands under the car-if it's on a jack only, you stand the risk of moving the car enough it FALLS and if you're underneath it...
Old Dec 28, 2007 | 07:21 PM
koskesh's Avatar
1997 E320
DO NOT bang on the wheels. very bad practice. loosen the lug nuts slightly to give the wheel like 2 mm of play room. then lower the jack gradually, the weight of the car will take it off like butter. do this carefully and make sure not to take the car completely off the jack so you have control over it.
Old Dec 30, 2007 | 11:39 AM
taylor210's Avatar
One little side kick...
Thanks for all you guys smart advise, I've had to kicked on center of wheels and side...( since I'm a black belt ). and came off very easily....
All you guys have wonderful new years & happy holidays!!
P/S, Hey you PROV1, Be gentle with your mouth before I knock your pretty ***!!!! You Pimp!!!!!!!!!!!
