How do I remove rear door panels
Robert Kieffer
1remove door pins turn it CC
2.remove cover under the door handle and remove the screw
3. remove plastic cover from the door lever(chrome)after you remove the cover remove the screw.
4 Unsrew the small screw on the door hinges
5 pull the door panel gently on both sides.
Check if the window regulator is shot you might need to replace it.
