Window washer not working
Old Feb 8, 2008 | 05:50 PM
eddyhascal22's Avatar
1999 CLK430
I'm getting no spray from the nozzles. Tank is full. It's pumping fluid but it's coming out under the passenger side sprayer then onto the ground. I cleaned the nozzles with needle and thin wire. How do I get the cover off to get to the hoses and sprayers from under the hood? I took out the 2 screws on the cover and released the plastic latches but there must be something more. Thanks for the help.
Old Feb 26, 2008 | 01:43 PM
rajssf's Avatar
1997 E420, 2004 C240, 2005 CLK 320 Convertible, 2012 E350 Sedan, 2020 C300
the 2 screws and the plastic lock tabs should let the whole panel swing out. Had same problem, the hose had come off on the passenger side.
