Brake master
Old Mar 12, 2008 | 09:54 AM
KompressorGpl's Avatar
Brake master
Hello! I have a W202 C200 Kompressor and I install on it a brake master from a W210 (1999). What is the difference betewen a 300 TD and a 290 TD on the type of part? Does all 290 TD came with automatic gear box? And base on that the servo master is differente from a car with normal gear box? Thank's!
Old Mar 12, 2008 | 12:55 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
All The INFO is in the EPC...as to part numbers etc
locate a copy of EPC as that is what you need to answer all of the questions
EPC will have foot notes re the items with or without certain extras
Or call the local MB dealer and ask the parts dept the questions...
As the 202 and 210 use different parts on the brakes
Master cylinder should be the same auto or stick
