need help no sound
Old Mar 16, 2008 | 11:59 PM
dylokjai's Avatar
00_e430_sport
need help no sound
just finish wiring up my alpine head unit to a scosche VW harness had to rewire the 12v and the 12v constant. now that i got power to it, i got no sound? anyone no what i did wrong? i wired up all the color matching the colors for speakers. but i think my problem is the bose amp signal? please help
Old Mar 17, 2008 | 12:15 AM
Marinel's Avatar
97 E320
check your wiring. This wiring diagram should help. Sorry for the large size...i just scanned it and didnt resize it.
Old Mar 17, 2008 | 12:07 PM
dylokjai's Avatar
00_e430_sport
any other help?
Old Mar 17, 2008 | 05:54 PM
algbenzo's Avatar
2000 E430 & 2006 ML 350
Factory amp turn on
The factory amp turn on wire needs to be energized. I don't remember what the wire color is but what you need to do is plug the factory radio back in and meter each wire to find out which wire goes from 0 to 12 volts once the radio is turned on. You'll notice that when this particular wire is energized, you begin to here sound. Once you locate this wire, you have to splice the blue w/ white stripe wire coming from the alpine harness to this wire. This allows your aftermarket head unit to turn on the factory mercedes amplifier. Good luck.
Old Mar 17, 2008 | 10:49 PM
dylokjai's Avatar
00_e430_sport
thanks
Old Oct 25, 2009 | 02:45 PM
xtrigger's Avatar
190e 2.3
anyone know which wire it is, I kind of cant check the voltage anymore as the factory unit needs a code to power up again... any help would be great... which wire to put the blu/wht line too
thanks
