Head Lights
If you want to upgrade only one choice, the Euro Lamp is the way to go.
http://www.bekkers.com/Merchant2/mer...=mhlighteclass
is to buy an aftermarket variant.
lowest cost...and correspondingly cheap construction and light quality is the
HID kit installed into a halogen projector headlight. for approx $500 this is
your basic, entry level, HID wannabe purchase. the beam output is mediocre
as the halogen projector is not calibrated to the HID bulb. also, the mostly
Asian construction is imprecise and the focus and beam spread is poor/uneven.
Higher up in quality is the same/similar Asian projector headlight assembly.
The difference here is that you pull the poorly made halogen projector and
in its place, you fit a quality made OEM HID projector. Cost for this comes
to approx $700....and a small bit of labor on your part to assemble.
here is a recent thread outlining the options...including some photo comparisons.
https://mbworld.org/forums/e-class-w210/233395-depo-headlight-hid-projector-retro.html
