Backlight out on Climate Control '98 E320
Old Dec 16, 2002 | 06:59 PM
johnny's E320's Avatar
1998 E320 Sedan
Question Backlight out on Climate Control '98 E320
Hey, I just joined this fine forum and have recently purchased my "new" 1998 E320. The backligting for the A/C control panel is out. The radio works fine. The cluster works fine. But the only thing that lights up are the 2 small red "Auto" lights on either side showing the climate control is on Auto. The rest is dark when I turn my headlights on. (the LED reads fine all the time) Can I replace this bulb myself? I'm pretty handy and have taken my BMW apart at times. Any help would be great!!
Old Dec 17, 2002 | 12:20 AM
cabby850's Avatar
A/C bulb for the backlit display
Hi,
I had the same problem with my A/C unit.
You can replace this bulb yourself if you have the A/C unit removal tool. Its just a very small bulb underneath the A/C unit when you take it out.
Ed
Old Dec 17, 2002 | 10:36 AM
1998 E320 Sedan
Question Where do I get A/C tool?
Thanks for the help on replacing my light bulb in my A/C dash display...can you tell me what tool I need to get the unit out of the dash and are there any websites that show this procedure?
Old Dec 17, 2002 | 03:12 PM
cabby850's Avatar
mercedes benz radio tool
Hi, the tool you need can be found on ebay.
goto www.ebay.com and search "mercedes benz radio removal tool"
They usually go for $10 to $20.
This will allow you to remove the A/C unit and the radio very easily.
Good luck.
Ed
Old Dec 17, 2002 | 06:02 PM
pakman's Avatar
98 e430sport
radio removal tool
Beckerautosound has them for $2-3 to the best of my recollection.
Old Dec 17, 2002 | 09:21 PM
USFBulls's Avatar
2019 E53 Cab
I picked up a set for $4.50 from my local Mercedes dealer. Let me know if you need the part number.
Old Dec 17, 2002 | 10:53 PM
E32K's Avatar
The radio removal tool can be bought from the dealership for less than $5. The bulb is around $3.
Insert the two removal keys into the two horizonal slits on the lower left/right sides of the climate control. Pull on the rings of the removal tool to pull out the CC.
The bulb socket is located on the bottom of the CC. Use a screwdriver or dime to turn the bulb socket and it pops right out. Replace the bulb and depress the clips to release the removal keys. Push CC back into console. Shouldn't take more than 5 minutes to change out the bulb... Good Luck!
Old Aug 26, 2013 | 06:45 PM
hdholdingsinc's Avatar
Mercedes 2001 E320 Sedan
Good info! Should this also work for a 2001 E320 Sedan? The repair guy I use has told me that the climate control must be removed and "sent away" to be repaired... quoted me a price in the neighborhood of $300.
Old Aug 26, 2013 | 08:14 PM
illest's Avatar
w210 AMG or S213
It should work. I had to do this in my 98 sedan a couple of years ago.
Old Aug 27, 2013 | 01:13 PM
renault12ts's Avatar
W215 CL500 2005
Run him out of town for his blatant fraud. Pull the unit as you would the radio...and fit the bulb yourself.
Old Aug 4, 2019 | 09:35 PM
Quamme91's Avatar
W210 E280
Originally Posted by Plutoe
Screw the light bulb-----does your girlfriend have an older sister!!!
rofl +10
Old Sep 25, 2019 | 05:31 PM
ghaffar23's Avatar
'08 CL600 with 152k km; '01 E430 4Matic with 433k km; '17 Porsche Cayenne with 130k km
Part No for bulb? I keep forgetting to ask my mechanic. I figure one of you guys know off-hand.
Old Sep 26, 2019 | 02:32 PM
raymond g-'s Avatar
99 E320
what i've collated so far....
https://www.benzworld.org/threads/0-...order.1720154/
Old Sep 26, 2019 | 04:05 PM
ghaffar23's Avatar
Much appreciated, raymond! Been a while, but I still check in every once in a while.
EDIT: For everyone's edification, the part number is 002 544 0294.
I found a place that has 10 of these bulbs in a pack for $16.75 shipped. I'm grabbing a pack and will update with results.
