AC Problems
#376
WOW, this thread goes back 10 years, impressive. A lot of 210 A/C problems.
Folks, I see a lot of problems similar to mine, cooling on passanger side not so much on the drivers side.
In some of the earier post there is refernece to a diagnostic procedure at:
http://www.eclassbenz.com/node/27
This link does not work for me, is there a new link?
I have got the item 1 - 8 info, but would like to know that I am getting that info during the correct conditions,
DougQ
DougQ
#377
98 E320 Wagon, 74 280C
The procedure at MercedisMedic did not work on my 1998 E320 wagon , 56,000 miles (90,000 km)..
Perhaps because it was exported to Japan initially, then to Canada by myself.
I found alternate procedures at:
http://import-era.com/threads/w210-hvac-diagnosis.1206/
http://import-era.com/threads/w210-a...tem-data.1210/
There are no error codes.
I took three readings; the first without the engine running, the second just after that with the engine running at operating temperature,
and the third at the highest ambient temperature of the day. All following the temp setting of 22C(approx 72F)
Ambient temperature almost the same as code #2. I was not sure where to set the fan speed?
These are all in Celsius.
Code #
1 21 23 28
2 20 21 29
3 20 41 30
4 20 41 28
5 18 21 31
6 20 73 91
7 04 07 09
8 19 30 40
There was no cold air with #3, but the compressor was engaged.
About a week ago I had attempted to add 134a, using a gauge set and a 12 oz can of 134a. Idle set to 2000 rpm.
I could not get the high pressure above 130 psi, and it fluctuated quite a bit.
The low side got up to 70 psi at times, and the cooling was intermittent, even though the comp did not stop.
Two days ago I was in stop and go traffic and there was no cooling, but when at highway speed I had
cooling on both sides, which was an improvement.
After the attempted recharge I was testing with temp set both to min, was alternating between EC on and off.
When EC first turned off, #7 would go up to16 then decline after 1 -2 minutes.
My limited experience is pointing to the expansion valve, but I defer to the forum wisdom.
If any other diagnostics tests are necessary, I am all ears. J
DougQ
Code #
1 21 23 28
2 20 21 29
3 20 41 30
4 20 41 28
5 18 21 31
6 20 73 91
7 04 07 09
8 19 30 40
DougQ
#382
I do nothing on my or customer car without looking at the VIN in MB EPC to define a part(s)------did you do that to define the correct part number bla bla
#383
Plutoe: Good idea, the epc makes no reference to any requirements.
As a matter of fact I could not find the condenser on the epc, well hidden.
I will check with my local dealer tomorrow.
Thanks for tour help.
DougQ
DougQ
#384
Well now you are going to get PO, but you are not searching correctly or you cant read the pictures and locate the condenser as shown
#385
I did find the condensor on a second check.
I have ordered a new comp, exp valve, gasket set and rec/dryer.
I have a vacuum pump, gauges, freon, synthetic comp oil and a special lube for the O rings.
It will be about a week before I can get to it.
A couple of questions before I start:
I have the specs for oil, and I know there are additional quantities for replaced components, do I add the total to the comp?
I had been running the engine at 2,000 rpm to add freon, but it seems that I should just be at normal idle.
Thanks for your patience.
DougQ
DougQ
#387
Received 1,749 Likes
1922 Ford Model T / no OBD
Code #
1 21 23 28
2 20 21 29
3 20 41 30
4 20 41 28
5 18 21 31
6 20 73 91
7 04 07 09
8 19 30 40
DougQ
Code #
1 21 23 28
2 20 21 29
3 20 41 30
4 20 41 28
5 18 21 31
6 20 73 91
7 04 07 09
8 19 30 40
DougQ
Might be weak compressor, but adding a can of R134 would answer the dillema.
#388
Thanks for the reply kajtek1, I had unsuccessfully tried to do that.
I will be replacing comp, rec/dryer and exp valve.
One more question while doing that is if I add dye, doI subtract that volume from the freon, or disregard it?
DougQ
DougQ
#389
Sound like you are going for expensive parts swap without actually checking what's wrong?
You can disregard the dye.
Those systems are pretty flexible. When label says about 1000 grams of r134,they will work with 400 grams and can be overcharged as well.
#390
Re: 1998 E320 Wagon
I have not yet started to replace a/c components, hopefully I will start tomorrow.
I have a question regarding the 134a fill.
On my car the sticker indicates the system requires 1.030 kg.
The cans I have are 340grams, so 3 full cans would be 10 grams short (1.020kg).
From comments it would appear that is close enough?
DougQ
DougQ
#391
Re: 1998 E320 Wagon
DougQ
DougQ
#392
I need further advice on my A/C repair.
I removed the compressor, those 6mm hex bolts for the connections were a real bear.
Previous to removal the a/c had worked at highway speed and I also noticed some oil
drops on the end cap seal of the compressor.
After removal I tried to drain any oil to check for contaminants, there was no oil.
I inverted it and manually turned it, it turned freely.
I compared the turning force with the new comp and they appeared the same.
I thought there might be some oil in the rec/dryer, but it too was empty.
All connections seemed clean with the exception of 2 that had a very small amount of fine black film.
So I am wondering if I should forge ahead with replacing parts and refill or is the lack of oil an issue.
I had thought I might disassemble the old compressor to check for any damage or particles.
DougQ
DougQ
#393
The compressor has only traces of oil on moving parts, when the dryer is build as oil trap and will not drain the oil from it (that's why you need to put new one with system overhaul)
When I would love to see open compressor - it might take expert to inspect the wear. Are you one?
#394
kajtek1, of course I am not an expert, then I would not need any help.
If I took it apart I could see if there were any particles attached to inner surfaces, but I am not sure it is necessary.
So, my question still is do I forge ahead or need to do deal with other issues first?
DougQ
DougQ
#395
If you are doing this out of curiosity to simply ascertain condition of internals, Id say no harm in opening it up to see.
In your situation, I think we are all assuming that the system has no leaks. But how do you know it isn't leaking refrigerant? What if all of this was due to a leaking hose like in the other thread?
#396
When I acquired this car (98 E320) 4 years ago it had 66,000 km, very little use and the a/c was marginal, I presume it had seldom use and the system deteriorated.
I had noticed leaks of oil from the compressor and I suspect that would also leak freon. I do not believe it had dye.
If any hoses are leaking I should be able to detect that when I vacuum the system, should I not?
It appears to me I will have to flush the system before I continue.
I have read some condensers cannot be flushed and must be replaced, is that the case here?
DougQ
DougQ
#397
The compressor very well may be the problem but with such extensive work to replace all the components, Id want to be sure there are no other areas of failure such as lines, valves. The vacuum will let you know if you cant achieve -27 inch or better but it will not direct you to where the leak is. Dye like shown in the link in the other thread above or possibly a sniffer will find others if any. The only items you can flush are the lines and evap. Condenser can not be flushed.
#398
Oil A/C questions 98 E320 - almost ready to get this project finished.
I am replacing the comp (done), rec/dryer, and exp valve on this project.
I have flushed all of the system, and would like confirmation about the amount of oil and where to put it.
After I started this project I needed to drive the car before the A/C was functional, so I added oil to the new comp and installed it.
Obviously the clutch will not be energized as the sensors on the rec/dryer are disconnected and all hose connections covered.
Initially I removed the old comp, tried to drain oil (it had none), I also drained oil from new comp, which had very little.
Consulting a MB chart for the 210, I added 120 cc + 10 cc (rec/dryer) = 130 cc of pag oil to the comp plus a bit of UV dye I had on hand.
The charts are shown here:
https://imgur.com/a/1DZGy4q
So, after flushing the system I believe I have to add an amount of oil equivalent to installing new components.
By my calculations that is an additional 100 cc, if I am correct??
The second chart has an odd bottom line about the comp oil needed to be 20 cc??
When I first added the 130 cc to the comp I put it in the intake port and turned the shaft a few times.
The unit came with rubber plugs and caps which I re-installed.
So where should I add the additional 100 cc of oil?
Also in the intake port?
Or to the rec/dryer or the intake hose?
Is turning the comp by hand a few times sufficient?
I also found this gem on the net from a Denso web site:
Thanks for any help.
DougQ
Never add oil directly into the compressor, always add it to the condenser, receiver dryer or second evaporator cycle.
Of course this time of year I might not need the a/c but I need to finish this project.Thanks for any help.
DougQ
#399
DougQ
DougQ
In my case I did replace the condenser (not sure if you did) so I inserted the amount into the condenser and oil into the separate replaced components respectively-I did the dryer last after everything else was filled and closed off. Added additional for the lines into the components to compensate for lines since I flushed those. I bought a cc syringe and squirted the required amounts into the parts while they were out. It will be difficult to squirt PAG into the evaporator in place due to space. You may need to use a bendable vinyl hose from the syringe into the evaporator.
Replace and lube al O rings. Be sure you add the right amount of refrigerant by weight.
#400
Thanks for the reply tall giraffe, I do like your idea of adding the oil to the individual components,
Did you end up with the same total that I have calculated?
That is 230 cc?
DougQ
That is 230 cc?
DougQ
