Question. Hopefully not that bad.
Old Jul 26, 2008 | 07:33 AM
MBE430!'s Avatar
E430
Hi all,
Recently my E430 4-matic has been having a noise coming from the drivers side wheel. It sounds like a bushing might be going. However it does not squeak when I don't drive it for a while (4 hours).
But after driving it for a half of an hour that squeaking noise arrives. And when I park the car and press down on that side, I can hear that noise. It is only on the drivers side and not on the passenger side.
Thanks.
Old Jul 26, 2008 | 01:30 PM
TMAllison's Avatar
09' E320
Warm metal and rubber expands. Check sway bar bushings and links. Try giving each in turn a shot of silicone spray until you locate the offender.
Old Jul 26, 2008 | 03:31 PM
MBE430!'s Avatar
E430
Do you think that I need to replace my shocks?
Old Jul 26, 2008 | 05:51 PM
TMAllison's Avatar
09' E320
You dont make mention of mileage....I'd look at all the other bushings first.
Old Jul 28, 2008 | 01:21 PM
MBE430!'s Avatar
E430
The mileage is 77,000. I had the rear shocks replaced around 3,000 miles ago.
Old Jul 29, 2008 | 01:56 AM
TMAllison's Avatar
09' E320
Your shocks ought to last longer than 77k. I did mine at ~200k. My rears were a little bouncey on the highway, fronts wernt bad. The old fronts were as stiff as the new Bilistein HD's were. Sachs/Boge made a good product.
