E200 kompressor problem with power at high revs
Old Aug 20, 2008 | 02:47 PM
panagath's Avatar
w210 E200 kompressor '99
Exclamation E200 kompressor problem with power at high revs
Hello, I have an E200 kompressor w210 1999 with the 193HP. I bought it about a month ago used...It's a really good car.What i have noticed is that sometime when i push it for high revs with the 2nd gear on for an overtake for example...when i put the 3rd gear in it does something like a stop of the engine and after that it is like it has no kompressor...it is really slow after that.what could be the reason??? thanks in advance.
Old Aug 21, 2008 | 12:23 AM
Z06EATER's Avatar
1997 C36AMG
have the
engine checked...maybe a pump is bad
Old Aug 21, 2008 | 09:42 AM
panagath's Avatar
when i turn off the engine and start it again it is ok with no problem...it's really annoying sometimes...when you overtake to loose power...
