Strange tranny issue
Old Aug 21, 2008 | 02:36 AM
h0rn3t920's Avatar
97 E420 W210, 95 Volvo 850 Turbo Wagon
Hey this is something i never thought to be a problem but idk i thought id ask.
My car when i shift it into a gear say drive, it will lunge forward as soon as i hit the gear and almost stall if i do not hold the brake with my foot. If i do, it will try to lunge foward but it wont, you can feel it and it wont almost stall it will be normal.
Now is this a normal thing?
Old Aug 21, 2008 | 11:00 AM
BoS7463's Avatar
1997 Mercedes-Benz E420
Strange
This just recently started happening in my 97 e420 as well, in drive it leans forward even w/ my foot on the brake, reverse it leans backwards and when i put it in park it leans a little towards the last gear i had it in (either backwards or forwards) is this the same exact thing youre talking about?
not sure if this has anything to do with it but i do know i am due for a tranny fluid change @ 120,000 and im @ 116,500 now..
Old Aug 21, 2008 | 12:55 PM
h0rn3t920's Avatar
Ya just about the same
Old Aug 21, 2008 | 10:35 PM
CrossT's Avatar
CLK430
Did you try resetting the learning?
Nice looking car by the way. Mine looks like (*&^ in comparison.
todd
97 E420
Old Aug 23, 2008 | 11:36 AM
TMAllison's Avatar
09' E320
Not sure what the OP's issue is....maybe something to do with the torque converter.
The second poster appears to have a bad shifter bushing or two.
97's have the 722.6 trans and need the proprietary MB fluid.
Old Aug 23, 2008 | 05:49 PM
BoS7463's Avatar
I reset the tranny, and mine still does it, so no luck there.
Shifter bushing cost?, procedure?, DIY?
Old Aug 24, 2008 | 12:47 PM
TMAllison's Avatar
09' E320
Couple of bucks. Mine is green. Will take an hour+ cause the belly pan has to come off. May need a long pair of needle nose pliers to help get the new one it as it is very stiff rubber.
See #27. http://www.detali.ru/cat/oem_mb2.asp...SGR=095&SGN=09
