Jerky Shifting Issue – Driving me Nuts
Old Sep 19, 2008 | 05:35 PM
Britrover's Avatar
01 W210 E Klasse | 02 W 463 G-Wagen | 06 Land Rover LR3 HSE
Unhappy Jerky Shifting Issue – Driving me Nuts
My 2001 E430 has a new bug that is driving me insane. The car shudders and is jerky when I speed up from 1st to 2nd. When slowing down, I can feel the transmission downshift in a jerky way from 3rd gear to 2nd.
The transmission fluid has already been changed as the car was approaching 90K miles. When I took for the car for the transmission fluid change my mechanic also noticed another issue that he showed me in person – I got to his shop and he has the car on the lift and explains I had a leak around the harness which has ruined two parts and the car requires two new parts plus the new AT fluid. They end up changing AT Conductor plate , a spacer plus the Transmission fluid.
However the car still shudders and downshifts in a jerky way from 3rd gear to 2nd. Has anyone else experienced this issue and has a fix? I will take the car back to the mechanic but wanted to find out if anyone has had a similar issue.
Old Sep 21, 2008 | 01:32 AM
Max Hughes's Avatar
Reset the transmission computer and see if that works. Theres a DIY on how to do it on benzworld.org I think.
Old Sep 21, 2008 | 03:08 PM
Britrover's Avatar
Thanks - I tried the Transmission computer reset procedure and the issue persists.
Old Sep 23, 2008 | 09:59 PM
TMAllison's Avatar
09' E320
Check the opposite end of that wiring harness and see if the fluid has wicked up to the ECU.
Old Jan 5, 2009 | 02:48 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Sounds like the rear freewheel unit (F2) in the transmission is on it's way out. Expect a overhaul soon, preferably before it fails completely
