How do you adjust front wheel bearing
2000 E320 wagon
Hello,
Newbie here. I am trying to find how to check the front wheel bearing on my 2000 E320 Wagon?
I tried searching but no dice.
Thanks,
Bill
Thanks,
Bill
1 Post
88 535is, 89 318iT
You just jack up the corner you want to check to get the wheel off the ground, then grab the wheel at 6 and 12 oclock and wiggle. If it wiggles, bad bearing, or on the W210, bad lower ball joint. The ball joints last about 50k miles. The bearings should be way over 100k.
Why do you ask? Are you tracking down a symptom?
