Headlight lens install
97 E Klasse 420 Sport/ 90 Honda Accord EX/97 Impreza Coupe
i just had a friend start pulling on them and i wedged something between the lens and the housing and i pulled them appart and clicked the new lenses on.
Search the W210 forum for other topics related to headlight lens removal and altering. Most of them will advise you to heat up the assembly. This makes the job much easier and helps to ensure a tacky, and effective seal once the new lens is put on.
having worked with lens removal and installation, it's my belief that the gray
matter is more a sealant/gasket vs an adhesive. as such, it is important that
heat be applied, so as to allow the material to reform itself to the new dips and
valleys caused by the lens removal/installation.
one of the weak points after such a modification, be it a simple lens removal,
or a major retrofit project, is the lack of follow up in sealing the lens. it is not
uncommon to then read of problems with condensation, water seepage into
the light housing, etc.
applying heat to soften the gray goo is such an easy task that to forego this
step has a slight risk. it only takes 5-10 mins to heat.
With the size of the gasket, and having the car washed since, I can't see how it could leak. I did check with a dealer and with the folks at European Auto Solutions{Former employees of Hatch and Sons} they don't use heat.
Thanks,
John
Thanks,
John
1 Post
1995 Mercedes E320 sedan
i unclipped the lens part from the light unit to expose the chrome interior of it with succesion..i now need to remove the lens from the grey part in order to paint the grey parts black without getting it all over the lens...i heated in oven and its stuck together pretty damn well..even melted my park light part a little..:S it was a good idea when i started...went down hill from there.
1 Post
planning to make the lights a bit darker without having to buy a whole new light...painting the grey parts inside the light black and tinting the small indicator lense at the top from the inside for a more smoked look..possibly install some angle eyes or something like that down the track....All would be good if i could just get that lense off
need to turn the temperature down to something like 35-40 C and leave it in the
oven longer. it's a slow and easy process.
you've not identified the headlight you're attempting to open up but not all
manufacturers will use the sealant. they may use adhesive (glue) instead and
that can make it very difficult to disassemble. if it is gray colored, it will likely
be the butyl sealant similar to this
1 Post
to make it more clear..i have removed the lense from the actual light. The lense is sealed to the part that clips onto the light, if you get what im saying, has anyone removed this part before?
the inner reflector is staked or cemented and not really something that folks
generally retrofit. there is an inner portion which pivots in response to the
headlight adjustment knobs on top.
1 Post
ok so i have completed one headlight...what i have done is removed the lens from the light...removed the inner indicator lens from the headlight lens and then painted all of the grey on the inside of the lens black...i have applied 35% tint to the indicator lense..i will post pics when complete.
