Check Coolant Malfunction light
Old Jan 6, 2003 | 10:47 AM
E 4.3's Avatar
2001 Mercedes-Benz E430
My check coolant level malfunction keeps popping up. The dealer tells me that I can add it myself. They also tell me that it is not the green coolant, but some pink type.
Does anyone know the brand of coolant that I should buy? The dealers around here require an appointment for such complicated work!
Old Jan 6, 2003 | 04:34 PM
MBDriver's Avatar
2001 E 320
I heard on here one time that the coolant color is different than green. I dunno how acurate that is though.
Old Jan 6, 2003 | 04:39 PM
E 4.3's Avatar
I believe so. The dealer told me to buy PINK coolant.
Old Jan 6, 2003 | 07:56 PM
allezdude's Avatar
e320 Wgn. 98, 08 R320 CDI, 2017 Chrysler Pacifica
The owner's manual says to top off with water between changes/flushes of coolant. However, if it's really low you probably have a leak and need more than just a few ounces, i.e., have the system checked.
Old Jan 6, 2003 | 10:24 PM
Dema's Avatar
i535
I heard that pink one doesn't require flushes.
E 4.3's Avatar
Yeah, that's what I did!
Old Jan 7, 2003 | 12:30 AM
phungpho's Avatar
2000 E430 Desert Silver
Top off with water is OK
It's OK to top off with only water. If the Coolant level still goes down then there's a leak somewhere. Normally, if it's leaking you should smell it (the coolant) when the engine is hot.
About the coolant, there are 2 kinds: one that needs to be mixed with water (50/50) and the other is ready to use (already mixed with water). They could be green, yellow and also pink. According to Mercedes, they recommend to use the Mercedes product (coolant). The color? I haven't seen it. Good luck.
Old Jan 7, 2003 | 02:30 PM
6.3's Avatar
6.3
2003 s500 sport
Use only MB coolant.
Just call the service department and ask for the MB coolant part number. It is a little more expensive then your regular green stuff but its better for the engine. All benzes use this pink/orange fluid. Less corrosive is what I heard. The cheap green stuff is corrosive and on my old benz it caused leaks. The radiator bottom neck pipe was corroded and leaked all the time.
Old Jan 7, 2003 | 02:31 PM
6.3's Avatar
6.3
2003 s500 sport
My e430 has the pink stuff.
Old Jan 7, 2003 | 04:15 PM
Dema's Avatar
i535
It looks like MB reduced cost for 2002 model using green stuff.
Old Nov 28, 2011 | 09:26 AM
Aarhuser's Avatar
1999 E55 AMG
My E55 has a coolant leak somewhere. The light came on, and i can see fluid collecting on top of the underbody shield, but the odd thing is that the coolant level has not changed in the reservoir. Anyway, you can go to Autohausaz.com i believe and they will have the coolant required. That site is so cheap for AMG parts.
Old Nov 28, 2011 | 07:39 PM
Altin's Avatar
98 E300 TD
If it says coolant display malfunctioning then you should check the sensor on the deposit or on the windshild washer deposit it happend to my uncles car and he changed the washer deposit sensor on the bottle , sometimes the computer confuses the one with the other even with engine oil level . check all levels and then the sensors
Old Nov 28, 2011 | 07:48 PM
Aarhuser's Avatar
1999 E55 AMG
There is clear odorless thick liquid on the pan. I think it may be antifreeze but I need to compare to what is in the res.
