replacing windshield
Old Oct 28, 2008 | 08:26 PM
michakaveli's Avatar
E300
whats involved. I still have the original MB windshield and have developed a large horizontal crack. It's been this way for a while as I'm afraid to have some dee dee dee start tearing apart all of the trim and hacking things up. I'm sure a SafeLite replacement should be sufficient. Just want to know what I should look out for OR be aware of..... not a big fan of surprises, especially bad ones.
car is a '97 E300 with no rain sensor.
Old Oct 28, 2008 | 08:56 PM
Air Marshall Eldritch's Avatar
John Deere
Safelite is fine. Those guys do that all day, so they know how not to screw up the trim. I would miss the signed white sticker for reasons I can't even articulate. I can find an OEM one if you want to compare prices. I was kicking the idea around myself because of all the tiny pitting my glass has.
Old Oct 28, 2008 | 09:04 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Watch out on the removal of the old glass..
When they remove the old glass..as the windshield is sealed in with sealer along with the weatherstrip...Most glass shops will use a cable to cut the sealer
and I Have seen a lot of them cut the metal body seam..and NOT touch up the metal...The rust will start and then you will have one big mess
Old Oct 28, 2008 | 10:06 PM
E300
good thing I posted.
Old Oct 28, 2008 | 11:20 PM
meooem1's Avatar
2004 e320 and 99 e320 wagon
i cheaped out on my old e320 sedan....had a new air conditioning system installed with the new windshield. there was a huge gap at the bottom of the windshield and it whistled when i got up to 50 or so and i got some fresh air too. called the guy back, more caulk, bad results. could not speak enough spanish on the phone to convey the problem. i went out and got my own windshield caulk and fixed it myself...also replaced the lower trim with replacements from duval. once again, you get what you pay for. $110 for a windshield...2hours of my time and $7 worth of caulk...good as new. go with autolite or other reputable company, unless you want new vents.
Old Oct 29, 2008 | 12:45 AM
fosmith's Avatar
2001 E430, Obsidian Black w. Ash/Orion Grey, 195,000 mi.
I asked the Mercedes dealer service rep who they recommend to replace window glass. He recommended a very good independent glass guy, not Safelite. Most of the trim just snaps off so it's not a very complicated job. As for the sticker in the lower right corner, you can get that from the dealer for $5 and your aftermarket windshield will look just like OEM.
Fred
Old Nov 5, 2008 | 10:39 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
i agree with mark i do glass at a dealer and its horiable what i see glass shops do, most of them just cut out the glass
very roughly and on the jagged old glue they put alittle new glue and then the windsheild. and youll never be the wiser
cause all the trim covers it ...glass guys are paid to be as fast as poss.
Old Nov 6, 2008 | 12:05 AM
fosmith's Avatar
It's probably good if you watch the technician do the work. The guy that did mine cut the old glass out with a blade and then painted the seal area with primer. I asked him why he did this and he said it was because the blade can scratch the metal frame and primer was to prevent rust from forming.
Fred
