Resonator Delete
Old Nov 13, 2008 | 08:39 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Resonator Delete
What is the advantage of the resonator delete if any and does one make up their own pipe or is there an after market source? My resonator has two pipes on the inlet and one large one on the outlet.
Old Nov 13, 2008 | 11:20 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The delete will shave about 40lbs off and will give a little better tone on the exhaust..
Horsepower gains zero
Take it to a Decent Muffler shop and have them make a insert to replace the center muffler
Old Nov 14, 2008 | 09:04 AM
ejsheltra's Avatar
Thanks Mark.
Are you using the E55 European exhaust on your wagon, meaning rear muffler and tips? Is it the same transverse muffler as the standard E320/430 or is it split into two rear mufflers?
Old Nov 14, 2008 | 09:34 AM
Yes I have the Euro E55 AMG Estate dual tip Exhaust that replaced the stock System..Its a single muffler as all estates have the same style exhaust
