E300 Engine not turning over
Old Nov 17, 2008 | 10:16 PM
EdzBenz's Avatar
W210 W140
Well, the cold weather we just got in Chicago must have done something to my starting system.
Here are the facts/symptoms:
-All electronics turn on, battery is charged
-After turning the key, the Glow plug light comes on for the usual amount of time and then shuts off indicating its o.k. to start
-I can hear the usual solenoid sound coming from the engine after turning key
-Turn the key, and absolutely no noise. No cranking of the starter, no sputtering, nothing at all
I'm thinking its my starter, or some type of a solenoid switch associated with it. My starter wasn't making weird noises before this happened, and typically in my experience a starter will make some grinding noises before it actually goes.
Any thoughts before I take it to the mechanic?
Old Nov 17, 2008 | 10:39 PM
lkchris's Avatar
'10 CL550, '12 GL550
About 95% of the time it's the battery.
Lights turning on is meaningless.
What is age of battery?
Old Nov 17, 2008 | 11:39 PM
EdzBenz's Avatar
W210 W140
Good point Kent, I did forget to mention that I attempted to jump the car with my buddy's SL500. I had the cables on there for quite a while, and still the same symptoms occurred.
I purchased the car 3+ years ago and have never replaced the battery. It might be good measure just to replace it anyway.
Old Nov 18, 2008 | 01:14 AM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
and I'm sure you have tried to lock and unlock your car...
Old Nov 18, 2008 | 02:46 PM
EdzBenz's Avatar
W210 W140
Kent was right... it was the battery. I put a new one in and the car started right up. The battery I replaced had to be the original because it was Mercedes Brand. Either that, or the previous owner always took it to the dealer and got hosed for a new battery.
Old Nov 19, 2008 | 11:10 PM
TMAllison's Avatar
09' E320
Actually, thier batterires arent that bad; roadside asistance will even come out and install for you and put the rear seat back together.
