retrofit latch vacuum door closer?
is it possible to retrofit the latch vaccum door closer on a w210 mercedes on all four doors? if so what parts are needed beside the actual vaccum itself? is there a lot of rewiring required? i am very interested on performing this retrofit. please help. thanks in advance
W203 slightly modified
'99 E430, '05 ML500, '15 GLK350
Well, you have the vacuum pump itself, but its control module has functions to/from:
A26/1 Left front door IR receiver
A26/2 Right front door IR receiver
A37 PSE control module, combined functions
N10/1 Signal pick-up and activation module (SAM) left front
N69/1 Front driver-side door control module
N69/2 Front passenger-side door control module
N70 Roof control panel control module
N72s15 RTR switch (trunk switch on center console)
N73 Electronic ignition lock control module
S6/1s2 Interior switch (CL)
S6/1s3 RHR unlocking switch
S15/1 Trunk release switch
S17/3 Left front door switch
S17/4 Right front door switch
S17/5 Left rear door switch
S17/6 Right rear door switch
S17/8 Trunk lamp switch
S86/1 Left front door lock switch (CF) (only (USA) (J))
S87/1 Right front door lock switch (CF) (only (USA) (J))
S88/2 Trunk lid lock switch (CF) (only (USA) (J))
Transmitter key
Antenna
Transmitter key
Antenna
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
