'00-'01 Taillights on '97E300...
Old Jan 14, 2003 | 10:55 AM
michakaveli's Avatar
E300
Just installed the outer portion of the lights this morning and went to MB to order the innner decklid lenses. For those whom have already done this cosmetic alteration, there is an extra bolt that requires a nut on the inside of the lamp on the upper corner. Without a nut there is it still sealed properly so that it doesn't leak? The lenses I just removed had this crazy plastic tab with a serious looking bolt [compared to the other screws] that held the lamp in that same place.
Old Jan 14, 2003 | 11:56 AM
USFBulls's Avatar
2019 E53 Cab
I changed both the outer and inner lights on my 99 E300. The inner needed some plastic shaved off but the mounting hardware was identical between the old and new. I don't know if there is any difference between your 97 and a 99. Good luck
Old Jan 14, 2003 | 12:33 PM
dlau88's Avatar
Wink
I made this change not too long ago. The outer lights were definitely a breeze, and the inners did required some modificaton! Somewhow, the left inner was seated much better than the right side.
The plastic nut set is for secuing the the inners to the trunk.
Old Jan 16, 2003 | 03:37 AM
Mitias's Avatar
99 E320
What are the differences between the two? Where can one go on the net to see the differences? Thanks.
Old Jan 16, 2003 | 05:25 AM
ShazAMG's Avatar
See Sig.
Ive got my rear lights, ill be replacing them on the weekend i hope i dont need anythign extra, I was told its a stright swap...
Old Jan 17, 2003 | 12:08 AM
E300
Hey Guys,
Picked up the inner tail lights from MB earlier. By looking at the lights, what is there to trim off, as in previous posts other have said to make them fit you need to trim some plastic off? Included is a pic of the inner side of the lights. Please someone fill me in to what must be trimmed. I haven't looked at the lamp currently in there yet.
Old Jan 17, 2003 | 08:06 AM
ShazAMG's Avatar
See Sig.
Originally posted by michakaveli
Hey Guys,
someone answer him man, I need to know this too....
Old Jan 17, 2003 | 01:58 PM
USFBulls's Avatar
2019 E53 Cab
I had to shave down the corner where you see the three ridges. I took it down to where it was almost even. You might have to shave some plastic off the side opposite the connector. Invest in a Dremel tool with the sanding wheel bit, that way you can do a little and check the fit. Good luck
Old Jan 17, 2003 | 04:24 PM
dlau88's Avatar
You will also need to cut some insulation at the opposite corner. Once you removed the original inners, compare the two, and you will see the difference.
Old Jan 21, 2003 | 02:14 AM
E300
Here she is... Completed!
Ok guys, I've included a couple of pix after my rear fascia lamp upgrade. I wish someone would have at least said tha after trimming that they would fit in like the original ones did. I wanted to keep trimming until they fit snug but realized that the lenses were getting paper thin in the spot requiring attention. I managed to trim the off enough to sit somewhat right ad then bolted them in ad it worked, so I left it at that. At least both side came out virtually identical in result. Enjoy...
The first pic includes a set of Xenon type bulbs. In person they bring out a sweet white output. Same bulbs for the blinkers as well, nice moochromatic thing going :-)
Old Jan 21, 2003 | 09:32 AM
USFBulls's Avatar
2019 E53 Cab
Nice job.
Old Jan 21, 2003 | 03:54 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Any reason why you got yourself the red/clear taillights instead of the red/smoked ones?
greetingz,
Old Jan 21, 2003 | 04:16 PM
E300
Here are the last few pix I am posting for this thread. Took them an hour ago in the daytime this time. :-)
MBenzNL -
I choose the clear/red ones because I like the monochromatic look of the lights. I like how white lighting blends with my smoke silver, and the front lamps. Personal preference on that... Damn I need those Xenons. :-)
Jim -
When we doing these on your E?
-Chris
Old Jan 22, 2003 | 02:54 AM
MBenzNL's Avatar
some slow@$$diesels
[B] Personal preference on that... Damn I need those Xenons.
Fair enough...in some cars clear/red does look better then smoked/red. I have several sets of OEM (used and complete) Euro xenonlights...in case you really need those...
greetingz,
Old Feb 2, 2003 | 01:30 PM
ShazAMG's Avatar
See Sig.
Hey michakaveli,
Nice motor man, we both need carlsson body kits ...
Question, did you have to replace the bulb sockets when upgrading your light? my old sockets don't fit correctly in the new rear lights that I have (the lights you have just installed).
cheers
Shiraz
Old Feb 2, 2003 | 06:23 PM
E300
Originally posted by *PaKiStAni-UK*
Hey michakaveli,
cheers
Shiraz
My new lamps came wiith bulbs and bulb sockets, along with the foam seal all around the lamp. Hope that helped :-)
Old Feb 3, 2003 | 10:48 AM
ShazAMG's Avatar
See Sig.
ok thanks alot, i only got the lenses didnt get any blubs or sockets, so it looks like I better get them.
cheers for the help.
Shiraz
