Sattelite Radio through Command?
01' E Fifty Five
Is it possible to set up sattelite radio through the command system. I have an 01 E55 with command and I bought the car with the sirius antenna on the roof of the car and the wires running in the passenger side, I can't find where they go after that. I also haven't been taking anything apart really. Is it possible the previous owner had it set up into the command?
E430 4matic 2001 & ML430 2000 both Silver / Ash
Display will only show AUX. You can only plug in audio source in to the AUX input such as satellite receiver or mpg player.
Good luck.
Sure you can use the AUX input for SAT SOUND.
You won't see any song titles on the COMAND screen and the COMAND does not perform as the SAT receiver and the buttons don't tune SAT stations.
OP will have to find the SAT radio somewhere in his car or purchase another one and find a way to mount the control/display unit within reach.
Then, yes, of course, sound output of the SAT radio can be routed to the COMAND aux input.
01' E Fifty Five
lkchris, sorry i should have been mroe clear in my original post. I have a unit from my old 320, The E55 I bught has the antenna all wired up and im assuming its wired from the outside into the glove compartment? Do you know what I'll need from there because I don't have the power wires from the SAT unit, they took them from me when my car was totaled.
