Torque values for transmission pan? 2001 E320
* Transmission Pan torx bolts[6ea]: ~106 inch/lbs
* Torx Bolt : #30
* Transmission Drain Plug: 5mm hex at ~18 ft/lbs
* Torque Converter drain plug: 5mm hex at ~20 ft/lbs
* Camshaft pulley nut : 27mm
Resource DIY: http://www.mercedesshop.com/Wikka/Trans7226Fluid
The cooler line is attached to a bolt that helps secure the oil pan right? If so just tighten it by holding the ratchet with one hand and tightening it until its firm, I broke one of those bolts, not a fun day.
