Blower Motor Replacement
Old Jan 21, 2009 | 12:34 PM
HOWSER's Avatar
2016 Z06/Z07, 2017 AMG GT
Can anyone verify a blower motor pn# A 210 820 68 42 will work on a 98 E320? If so are any changes needed to get it to work?
Thanks.
Old Jan 21, 2009 | 04:37 PM
TMAllison's Avatar
09' E320
You need to check using your vin and pay particular attention to the chassis cutoff numbers (last 6 of vin) on the parts site.
Blowers, reg and conductor plates were updated and if you are lucky you'll be able to purchase them as components rather than as an assembly.
Old Jan 21, 2009 | 05:35 PM
HOWSER's Avatar
I have the earlier blower motor as it is now. The one mentioned above I bought off eBay w/o the regulator in good working shape for very little. I was hoping that it was the same motor but I see now it is not.
Can this motor be fitted to the earlier model 98 (before the update)?
I don't know if this makes a difference but I did do the regulator update mentioned in the sticky this past summer (used W140 regulator).
Eric
Old Jan 21, 2009 | 10:44 PM
TMAllison's Avatar
09' E320
I am not certain if it can be used or not.
If not, PM me. Might have a use for it.
