Need to replace failed EC HVAC switch
Old Apr 16, 2009 | 12:24 PM
EdzBenz's Avatar
W210 W140
I posted this on the W140 forum because my question is in regards to my S500. No response there, so I figured I'd ask on this forum since my climate controls look virtually the same on both models (W210, W410).
Here's my problem: The EC (economy) HVAC switch on my 1999 W140 has failed. Can I replace only the switch, or must I obtain the whole switch panel? In either case, does anyone have the part(s) and instructions and/or video that explain the installation? Thanks.
Old Apr 16, 2009 | 01:14 PM
TMAllison's Avatar
09' E320
Your EC button won't light up or won't turn off?
Old Apr 16, 2009 | 02:07 PM
EdzBenz's Avatar
W210 W140
The EC light won't turn off.
Old Apr 16, 2009 | 03:03 PM
usaims's Avatar
98 e320
So, there is a red light on the EC button and you can't turn it off, correct?
If that is true, it's more likely that you have problem with your AC not your switch.
Are you going to tell me your AC is working?
Old Apr 16, 2009 | 05:00 PM
TMAllison's Avatar
09' E320
Ed - You should pull the error codes and actual values to help diagnose.
http://www.eclassbenz.com/node/27
To erase error codes hold both auto buttons 3-5 secs while on the error screen. FF means no more codes. Do erase them as sometimes a fault code is keeping the system from comming on. Do note them first.
