Activated Charcoal Button on Climate Control....
Old Feb 4, 2003 | 11:00 PM
michakaveli's Avatar
E300
What does this feature do?
'97 E300
Old Feb 4, 2003 | 11:06 PM
awiner's Avatar
2003 CL55 AMG
When on, the airflow comming into the vehicle is passed through an 'activated charcoal filter', thus, removing odors and such.
Old Feb 4, 2003 | 11:54 PM
E300
Is it ok to have it on all the time? I know there is a filter for it...
Old Feb 5, 2003 | 12:11 AM
awiner's Avatar
2003 CL55 AMG
It is not recommended to have it on all the time. Only when needed. Supposedly it will reduce airflow and heating up or cooling the interior vehicle will be effected. I also believe it will shut off after so many minutes.
Old Feb 5, 2003 | 12:24 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Adam's right, plus activating the filter also inhibits the ability of the air conditioning system to dry the air, so the windows may fog up if the charcoal filter is left on too long. The W210 already has 2 dust filters that are filtering the air constantly, so the charcoal filter should just be used to filter odors.
Old Feb 5, 2003 | 11:20 AM
jswedberg's Avatar
C32 AMG
Does the filter "wear out"? I imagine it would lose its effectivness eventually.
I believe it is quite expensive. How do you know when it is time to replace it? When those odors keep on coming?
Old Feb 5, 2003 | 11:51 AM
awiner's Avatar
2003 CL55 AMG
Yes the filter does lose it's effectiveness over time with use.
There is a determined replacment interval that your service book should list.
