engine mount, bushings?
Old May 3, 2009 | 09:20 PM
newg's Avatar
1998 E320 W210
Question engine mount, bushings?
Hello, I am a new here. I need your expertise.
My car feels like it is rocking back and forth (not real harsh, but unpleasant) during idle in P or N. I am guessing it is the engine mount. I believe there are two. How can I be sure it is the engine mount? If it is, how difficult is it to replace them?
My second concern is that, at speed up to 75 mph it feels fine but above that the car feels like it swerves. I don't know where to begin checking or how to check. I need your help please. I would greatly appreciate it.
Old May 3, 2009 | 11:33 PM
Air Marshall Eldritch's Avatar
John Deere
How many miles?
Old May 4, 2009 | 02:16 AM
newg's Avatar
1998 E320 W210
Originally Posted by Mister Brenton
How many miles?
The car has just over 130k.
Sorry I didn't mention it.
Old May 4, 2009 | 07:21 AM
uberwgn's Avatar
e300d
I did the mounts on my E300 this weekend. Parts were about $150. Access is good/ez on the inline 6...the V6 may be a different story. Change-out was no more challenging than changing a flat tire. However, car must be safely supported so you can work underneath.
My car has 70k miles, mounts were compressed compared to the new ones.
These cars tend to be hungry for front end parts. When were the ball joints last done? How is tire wear?
Old May 4, 2009 | 08:06 AM
newg's Avatar
1998 E320 W210
Thank you for your response. 1st of all, I just got a new set of tires. That seem to help a bit, but not really. It does ride a lot nicer. The old set of tires were really bald and dangerous. It did help the ride a lot. 2nd, I have never had the ball joints done. How can I tell, if I need it? If I need to ask you some questions, may I contact you? either ways, let me just say, "thank you." Any other advices would be great. Thank you
Old May 4, 2009 | 02:13 PM
John Deere
Definitely get the engine and tranny mounts all done together (3 total). For sure they are squashed.
Old May 4, 2009 | 02:40 PM
newg's Avatar
1998 E320 W210
Thank you for your advice. Now my questions is "is that some thing I can do?" How difficult is it for an average guy?
Old May 4, 2009 | 03:55 PM
uberwgn's Avatar
e300d
I'd have your front end checked ASAP if those ball joints and other typical components have never been touched....for everyones' safety
Old May 4, 2009 | 07:38 PM
newg's Avatar
1998 E320 W210
Your probably right. I believe I need to do that right away. Is that something average DIYer can do or does a proper shop needs to do it. I am not the wealthiest person around. I would appreciate your input.
Old May 5, 2009 | 08:12 AM
uberwgn's Avatar
e300d
These are the most fundamental safety issues - - whether Honda or Mercedes. Doesn't CA have some sort of annual safety inspection where stuff at this level would be caught?
Is this a DIY task? Not really, not unless you have specific, previous experience and the tools. You're going to need an alignment when the job is complete. I'm not trying to scare you or put you off, but it's entirely possible you're going to have a list of front end components that are far beyond their wear limits.
You should probably track down your local MBz specialist if you don't want to go thru the dealer. You could post a WTF (Want to Find) in the regional section or go to the Mercedes Shop Forum (now called peachparts.com or something to that effect) where they have shops listed by state.
These cars can provide exceptional service and longevity when maintained. However, it can also become a nightmare when routine care and inspection are ignored.
Good luck Ohh, don't forget those motor mounts!!
Old May 5, 2009 | 02:00 PM
newg's Avatar
1998 E320 W210
Thank you for your advice. I do appreciate it. I am still contemplating if I should try to do it. I do have tools, but what I am wondering is that, do I need special tools to take the bushings out... things like that. Oh, and how difficult is to replace the engine mounts and transmission mount. I like to do what I can before taking it to the mechanic. Please advise...Thank you.
Old May 5, 2009 | 02:45 PM
TMAllison's Avatar
09' E320
The engine and trans mounts aren't too difficult. Takes a few hours usually.
The front end work requires a Klann spring compressor, 25 ton shop press with MB fittings to press bushings in and out, MB ball joint puller, etc. It's a weekend type of job typically.
Old May 5, 2009 | 03:58 PM
uberwgn's Avatar
e300d
Please advise.
I offered what I know. My experience in this area of the car is limited to springs, sway bar components, end links, shocks, brakes, bearings.
I mentioned above about the engine mounts on a V6. I don't know if it is comparable to the diesel (which is e-z). It's my guess that access is not as good.
Old May 5, 2009 | 06:21 PM
newg's Avatar
1998 E320 W210
I thank you for your input. I will try to do the engine and trans mounts. Do I have to have special tool for removal and installation for mounts? I have the basic tools but nothing out of the ordinary. I guess I'll be looking for a shop to check out and replace the bushings and ball joints. I am just an average guy trying to save money and learn a little bit. So, I really appreciate all the input from here. Thanks again.
Old May 5, 2009 | 09:18 PM
TMAllison's Avatar
09' E320
Here is the diargam of your mounts. Looks like the same mounts that UBERWGN and I know and love. http://www.detali.ru/cat/oem_mb2.asp...SGR=015&SGN=02
Tom did his more recently than I, but IIRC you will need some hex bits, sockets, extensions and possibly a universal swivel attachment.
Best thing to do is to crawl under there and check it out before buying parts.
I elected to let a shop do my LCA bushings because of time constraints and special tools needed. They replaced bushings rather than using replacement LCA's with factory installed bushings; pretty sure they won't offer to go that route again on the next MB customer.
Old May 5, 2009 | 10:49 PM
John Deere
Think about what you wrote. People take the first statement at face value. And then the second statement...
Old May 7, 2009 | 07:39 AM
uberwgn's Avatar
e300d
The bolt on top of the mount is 16mm....a 12pt socket is helpful. The lower bolt, accessed thru the frame rail, is 13mm.
I have a long extension that permitted me to access the upper bolt with ease. You may be able to do so from below with a standard 16mm box wrench. Again, my comments are based upon the inline 6 motor.
Yes, a swivel/universal jt tool will be helpful.
Old May 7, 2009 | 02:33 PM
TMAllison's Avatar
09' E320
I've apparently missed your point..... The OP's asking about two different projects, mounts and LCA bushings. The first is pretty easy for most DIY'ers, the second is much more involved (allocate a weekend) and requires special tools.
