Servicing the Monowiper - How do I open the hub assembly?
Was thinking about lubing the monowiper assembly, as the elipical orbit must means it has more linkages. Any advice on how to open the hub up?
Thx!
Thx!
2014 ML350 4Matic
Lift the plastic cover at the base of the blade assembly, remove the socket head bolt and pull the blade assembly off. The reach under the edge of the plastic hub cover with your fingers. Pull outward where you feel the dimples and pop the cover off. The linkage will be exposed.
