Ticking noise when accelerating
All i know is that the exhaust required some welding. Car is a 430.
Any ideas? Loose manifold? Hole in the exhaust or something.
Thank you!
Thank you!
My vectra used to tick from the exhaust and for about 10-20 minutes when you parked up, if it was not oem it might be the heat causing the metal to tick expanding when hot and contracting when cooled.
if youve messed with the exhausts tube diameter it could causee it too
