w210 multi contour seats
Someone here suggested it is possible to swap out the front seat(s) for these upgraded (better?) seats.
How much might this cost? Do you have to buy them new, or are they pretty easy to find on the used parts / junk market?
What do the upgraded seats offer over the standard seats? (Lumbar support I hope?)
Thanks,
Kieran
- adj. air bladders: front edge of seat bottom, left/right side of seat bottom,
left/right side of seat back, lumbar, and below lumbar region. each bladder
is metered through air control pod located between seat bottom and center
console.
- leather may be different/higher quality over std E320 leather, especially
if part of the Designo package
- cost is whatever the seller has tagged it...usually from a salvaged vehicle.
I paid $1500 for mine, front seats, rear bench and back, door inserts, and
matching headrests. If I remember correctly, it originally was offered by
Potomac German auto
- finding multi contour with matching leather to your rear seats and door
inserts will be challenging
- you'll need to source hoses and t-fittings for each chair....back to the
PSE pump beneath the rear seat, ending with version coding so that the
car knows that the seats are there.
The features are great to have and are used daily
Install is not that bad
replacement wood panel with switch assy/seats/new Pse pump and lines also wire harness
http://www.mbenznl.nl/index.php?opti...id=28&PageNo=2
mods. if memory serves, don't you have an older 210 in which the steering
wheel was upgraded to a model which sports the control buttons....and
which controls COMMAND? I couldn't remember which model year you
have. tnx
But one can add the multifunction steering wheel to a early car...
takes a replacement contact ring ..wiring and a steering wheel with air bag
