REAR INTERIOR LIGHT?
00_e430_sport
I took my right rear door panel off...*my window regulator broke again twice in one year* anyways i removed the door panel now my rear interior light stays on for a while before it turns off..i havent put back the panel yet as my part will not be here til friday just getting it ready. Is that normal? all fuse checked out ok.
00_e430_sport
this happen after i removed the door panel. when i lock the door 5sec later the front dome lights turn off and the rear dome light stay on for 10minutes before turn off i timed it..LoL
2000 E320 RWD
Oh no, I haven't heard of it before, at least it turned off in the end. As you said it could be related to the door panel, three days before it can be fixed, it could be related to the door switch, no other suggestion till the door panel and window is fixed. Good luck.
97 E420 90 300E
There is a pin that gets depressed and turns the lights off. Make sure that when you put the panel back on that it is on properly and the pin is being pushed in far enough to deactivate the lights.
