60K service (W210) questions
E-320
Hey guys.. Hope you are all doing good.
I own an E-320 (W210) 1999 with 62K miles. Have some questions...
Does any of you know if there is a special set of steps which should be followed when changing all 12 spark plugs on these cars?
Does any one of you have a Mercedes Shop in South Florida that you would care to recommend ?? (someone you have worked with before).
Does any one know what all is included in a 60K mile service for a W210?
Thanks ahead of time
![Cool](https://mbworld.org/forums/images/smilies/cool.gif)
1997 E420 Sport
Can't help with the first two questions but might have some value to add with the third.
The 60K major service should include the standard items like an oil change with synthetic, spark plug change, air filter, fuel filter, pcv valve, cabin air filter, belts, hoses, alignment check, balance/rotate, radiator drain and refill, etc.... Your maintenance book should have more info or you can find it on the web.
Other things that my mechanic recommends, but that you may not find at the dealer, are:
change differential oil and refill with synthetic
drain transmission and replace with synthetic (new filter too).
battery load test and perhaps just change the battery
replace all engine vacuum hosing (it gets pretty brittle)
AC test and service
AC test and service
