Radio has loss of power but fuse ok????
2000 E320 Wagon, 1970 250c
I have lost the radio once before on my 2000 wagon. Checked the fuse found nothing, ever swapped out fuses just to be sure. Later on doubled check fuse and found it blown, new fuse radio back in business. Now we are back to the same issue. The instrument shows flat lines when you toggle to audio not OFF? Not sure what to do, fine car but not much fun with no tunes.
Anyone have any ideas?
Thanks,
Blake
Thanks,
Blake
be sure you've examined for blown fuse at the rear panel of the radio....as
well as the fuse beneath the rear seat. when fuses blow, there is usually
a reason. when it blows multiple times, you need not just replace it but look
for a serious short situation.
