w210 transmission help
Old Aug 23, 2009 | 10:54 PM
brabusv12's Avatar
w220 w210 w202
i have a 97 w210 trans will not shift out of first gear changed fluids and tran case any help appreciated thanks
Old Aug 24, 2009 | 02:56 AM
BrabusE420's Avatar
E420
Do you get a check engine light? If you do check the fault code. If you get the following: P0715 Transmission Speed Shaft Sensor Circuit Malfunction.
You need to get your speed sensor located on the transmission valve body replaced. this is one whole part. Just got mine replaced and runs as good as new. Very smooth.
Good Luck.
Old Aug 24, 2009 | 12:33 PM
TMAllison's Avatar
09' E320
Limp home mode would be 1st, 2nd and R only. Trans codes must be erased after repairing before it will work again. OBDII will only show generic trans codes and will NOT erase the underlying MB specific codes.
Suggest having it scanned using dealers SDS laptop.
Old Aug 24, 2009 | 12:44 PM
brabusv12's Avatar
w220 w210 w202
hi thanks for the responses i changed the entire valve body does new valve body come with the speed shaft sensor or do i have to purchase seperatly.
