Igintion/ Key help!
Lately every time i try to use the main key, sometimes it does not work. It doesn't unlock the steering wheel and doesn't allow me to start the car. I put it in and i pull it out constantly. Out of about 10 times it works maybe like 3 times out of the 10. Sometimes i keep the key in there for like 5 seconds and then it releases the lock and the i am able to start the car.
The second key i have is the valet key. It seems to definitely work a lot better than the main key. 9 out of 10 times it works back to back each time i put it in and out real fast. The one time that it doesnt work may be when i switch from the main key to try the valet key fast. Im thinking it was trying to read the main key but while i switched it to the valet key it doesnt respond right away? I guess because i am putting it and out too fast?
But over all it seems like its working a lot better than the main key.
Yesterday i cleaned the infrared ignition with a q tip with some cleaning solution. The main key looks beat up a bit and is the original key that has been used constantly for 10 years now. My question is it a problem with the key or does it sound like a failing ignition. It seems like there is trouble reading the key.
I just need some advice, opinions. I dont want to buy a new key unless that is what i need.
Thanks in advance.
