will 1997 E420 H&R springs fit on 1996 E320?
Old Feb 25, 2003 | 12:06 PM
btx's Avatar
btx
shouldn't be a problem, right?
Old Feb 25, 2003 | 01:23 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
they should fit, however, I believe H&R makes springs are based on the weather the car is V6 or V8 because of weight of the engine. So the V8 springs may be be more - stiffer or taller or something to correct for the added weight. All speculation.
Old Feb 25, 2003 | 04:32 PM
M Brabus's Avatar
97 E420
actually, i don't think H&R differentiates between the two models. H&R has the same part #. there is no fitment problem, it'll fit. but, the car will be slightly higher on the 320 (compared to 420) due to less weight in the front.
Old Feb 25, 2003 | 05:47 PM
E55 KEV's Avatar
Veteran: Air Force
some good news!
I went to www.hrsprings.com and they now list shocks & Sway Bars for W210.
