Which plugs OLORDD!!!??
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Guru, I need your help!
Which spark plugs do I need for my 2000 E320???
Thanks in advance!!!
http://www.autohausaz.com/search/pro...2@Spark%20Plug
The F8DPP33 (7422) is the correct Bosch spark plug. That's a great price also; the cheapest I've ever seen. You need 12 of them. Do not use the other multi-tipped plugs.
I just put the 7422 plugs in my car a few months ago. runs perfect. They are double platinum plugs and come properly gapped. There is a specially designed tool available for prying the wires off that makes the job much easier. It costs around $20 or perhaps you can borrow one from a member. Ohlord sells it
The NGK 7090 single platinum plug works fine and is available for about $3 at most autopart stores. The NGK double platinums are about $12 each.
I'd go with the Bosch 7422
2000 Mercedes E320
Hi,
I have 2000 E320 also, and replaced my plugs with NGK7090, as per ohlord's recommendation, and used the wrench that he has available too. Everything worked terrific!
Brent
1 Post
2000 E 320S4 210.282 4Matic Estate
Agree with 01BlackE320
I got the Bosch 7422 as well. Cannot enphasize enough the fact they come pre gapped. Do not know if it's the case with NGKs even though they're also high quality and OEM. Hope that helps.
Cheers
Cheers
