1 Inch Paint Bubble/Rust? 2000 E430
Old 10-18-2009, 04:42 PM
Patz's Avatar
2000 E430
Hey guys,
I just went out to grab something from my car when I saw something horrifying. About a one inch patch of paint on the front-left fender that is bubbling/peeling! It's really very small and hardly noticeable, but I'd like to take care of it as fast as possible.
Does anyone have recommendations on the best way to take care of this? I'm thinking maybe I should take the car into a detail shop and see if there is any way this can be coated? I'm not looking to have it look like new again, but any kind of preventative measures I can take would probably be good (for the entire car). I have a 2000 E430, so the car is starting to show it's age, but the paint bubbling was surprising!
Any suggestions would be much appreciated!
Thank you.
Old 10-18-2009, 08:33 PM
raymond g-'s Avatar
99 E320
no other choice, really. sand down to bare metal, prime, and repaint.
the fact that the paint is separating from the undercoating means that
adhesion has failed. if you fix this on the cheap, you may simply be
sticking a bandaid on it. you must get to the root cause of the failure.
if it is rust, it is guaranteed to spread unless rust is attacked directly.
your 1" bubble will result in about 12 inch repair (or more) depending on
result of the inspection.
Old 10-18-2009, 09:30 PM
Patz's Avatar
2000 E430
Uggggh, would that mean I would have to get that entire fender repainted or do you think a small portion of the paint could be patched up? I'm probably looking at at least $500 worth of body work here...
Old 10-19-2009, 03:35 PM
h0rn3t920's Avatar
97 E420 W210, 95 Volvo 850 Turbo Wagon
be advised, rust is like cancer. I had the same thing appear on my trunk lid, and i got a really good body shop to repair it. Looked great for about 6 months, and now its back in the same place.
Quick Reply: 1 Inch Paint Bubble/Rust? 2000 E430
