Smartkey in ignition; no start woes
- Shut car off, to go do something for 5, 10 minutes
- Put Smartkey back in ignition, and NO SOLENOID SOUND
- Jiggle, jiggle, jiggle, tap tap, swear, swear
- Call MB Roadside assistance, and while on phone with them, solenoid unlocks.
- Cancel my roadside assistance visit
- Drove home
- Tried to start car immediately after switching it off, same as before NO SOLENOID SOUND.
- Jiggle, jiggle, jiggle, (unlocks once) but then doesn't again
- Jiggle jiggle jiggle - nothing.
- Call MB Roadside assistance, and this time they make two suggestions:
- Leave the key in the ignition for awhile to allow the key to "synchronize"
and
- Try cleaning the end of the key with a soft cloth
Well, I cleaned the end of the key, and the thing worked immediately. I inserted the key several more times, and it worked each time. I waited 5, 10 minutes and it worked again.
Does the key communicate over IR with the ignition lock? I don't think my key was very dirty at all, so I'm not sure if this is a freak occasion, or if I'm going to be stuck with the problem again tomorrow AM....
Just to cover all bases, how old are the batteries in your smartkey? Have you tried putting fresh batteries in them?
Replace:
Electronic Ignition Lock (EIS)
Qty:1 210-545-03-08 SWITCH
Qty:1 208-766-19-06-9999 ELETRONIC K (that's all it says)
Along with assoicated labour charges for installation, initial diagnosis, testing, and control module version coding.
Fortunately everything had a "N/C" next to it, because of the Starmark Warranty.
1999 E300, 53K miles
