rear tailight problem
Old Mar 10, 2003 | 09:45 AM
cmp's Avatar
cmp
my rear brakelights constantly go out (especially on bumps and when shifting to reverse), which is due to the bulb holders loosening , so i have to adjust the bulb holders all the time. i know this is a problem on the earlier w210s. anyone solved this problem ?
Old Mar 10, 2003 | 10:31 AM
E430 George's Avatar
1999 E430
Had somewhat of a similar problem, the rear driver side tailight kept on going of, especially on breaking. Everytime I got into the car and started it, as soon as I pressed the breaks to shift into drive, "lamp defective" came up on the LCD. Tried changing the bulb, which helped for couple of days and then the problem returned, turns out it was the bulb housing defect which kept on burning the bulbs. Took it to the dealer couple of weeks ago, who fixed it under warranty by replacing the whole break tailight housing, seems to be fine now (knock on wood ). From what I understood it was a common problem on the W210.
I am not sure if this is what's causing your light to go out, but hope this helps, and good luck fixing the problem.
Old Mar 10, 2003 | 01:12 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
W210 Tail Light bulb holders
There Is a KNOWN problem with the W210 and Other Models
for Melting the Contacts..It overheats the Plastic and Causes loose connections...Bulb check lite
Old Mar 10, 2003 | 06:59 PM
dieseldriver's Avatar
97 E300
Since I am out of warranty and not interested in spending $ to fix MB's inferior engineering, I found my own fix. I wound fishing line ( monofilament) behind all the metal tabs that make contact with bulb assembly, making circumferential rings around the hole. The effect was to push the tabs back out and made available some added support to the tabs to allow them to make and hold sufficient contact with the bulb assembly. Incredibly the heat does not melt the monofilament. The plastic MB used in its final design solution was way off the mark. This may seem a hill billy solution, but it overcomes MB's poor design. Take your choice.
