Transmission leak
Leaks can be hard to track down especially if they start higher up and drip over lines and nooks and crannies.
As I'm sure you know the movement of air will tend to push fluids towards the rear.The only thing that has worked for me is to get under the car and do a thorough cleaning job. Then inspect regularly to see where the leak shows up first.
BTW, if you want, you can confirm your transmission submodel number at this site. Just enter the VIN. Lots of other info as well.
http://old.mbclub.ru/mb/vin/?lng=eng
Good luck.
