Rear door lock not unlocking
Old Jan 13, 2010 | 07:26 PM
Tamerz's Avatar
2002 E320 Sedan
Hello all,
I have a 2002 E320 sedan. The remote unlocks all the doors except the rear drivers side. It will lock it fine, but it does not unlock it. Is there just a child proof setting somewhere I am missing or is it just broken?
Tamerz
Old Jan 14, 2010 | 10:21 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
It's not a childproof setting, that affects both rear doors and it's a switch on the panel containing the master window switches. When activated you'll see a child icon. Does the button raise when you unlock it but you can't open the door? Can you unlock it manually by raising the button?
Old Jan 14, 2010 | 11:21 AM
Tamerz's Avatar
2002 E320 Sedan
The button does not raise. If I manually pull it up the door opens just fine. I would have just assumed it is broken but then the button goes down and the door locks just fine when I use the remote to lock it.
Old Jan 14, 2010 | 11:27 AM
Musikmann's Avatar
It's not completely broken then. You can rule out the PSE (vacuum and pressure) pump and line to it since it works to lock it. There is a unit inside the door (which I think is called an attenuator) which might be going bad.
Old Jan 15, 2010 | 04:19 PM
Tamerz's Avatar
2002 E320 Sedan
I'll have to check that out. Thanks for the info.
Old Jan 15, 2010 | 07:01 PM
Red66GT's Avatar
2008 S63 AMG Designo Edition
Do you hear a hissing sound coming from the door? I had a similar problem with my driver rear door and it turned out there was a tear in the lock actuator boot which was causing a vacuum leak (hence the hissing noise).
Old Jan 15, 2010 | 11:23 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
I Have done several line repairs on the l/r doors on 210s ...remove the door panel and check the line going to the lock assy...Most leak inside the boot between the door and the body....B Pillar...
Old Jan 16, 2010 | 11:54 AM
Musikmann's Avatar
My bad. I called the unit an attenuator and that was incorrect. Thanks to Red66GT for the correction of actuator.
Old Jun 11, 2013 | 02:08 PM
dsm1's Avatar
02 ML55, 02 E320, 98 SLK230, 85 300SD, 84 300SD, 914GT/V8
Is there a vacuum "Tee" located somewhere to split vacuum for both rear doors? My 02 E320 fronts lock/unlock fine but both rear door locks are inop. I'm wondering where to start before digging into the doors.
Old Jun 11, 2013 | 02:12 PM
Tamerz's Avatar
2002 E320 Sedan
I completely forgot to post what the problem was. There is a plastic part that physically pushes/pulls the lock up and down. Part of it was broken so when you tried to unlock, there was no plastic there to push it up. The part that pulls it down was still in place. Had the part replaced and it has worked perfect since.
