Headlight Replacement DIY?
I am a new member to this forum, today I purchased a '97 E320 and I need to replace the headlights on the car, I am still in the process of looking for a set of headlights but would like to see if there is anywhere on the site where I can search for DIY on our W210 or is that not an option? I need a guide on how to remove those headlights as I like to work on my own cars.
Thanks in advance!
P.S. How are the parts on our cars? are they all the same through out the years or are the 96 and 97 different than the later models in most of the parts?
have fun. exceedingly simple process, as far as MB R&R goes.
tip, save this download 400+mb but well worth it!
here is the front end....
http://www.edsoto.com/e320/w210/disassembly.htm
and here is the ISO file which downloads all the videos and supporting
html to create your own standalone of this info on your own PC.....
http://edsoto.com/E320.iso
that's what I don't remember -- what he used! Sorry.Do some searching, and you will find this, however. A couple of things I know: there is a Meguiar kit designed specifically for headlight repolishing, and a 3M kit as well. Others have wet-sanded then buffed. Posted photos show *sparkling new* headlight appearance after this is done.
Save your $$ for the real maintenance work you will no doubt have to do!
Meguiars PlastX
Meguairs, 3M, or similar Headlight Repair kit
Wet Sandpaper by hand (start fine, go coarser until you get it clear, then go fine to smooth it out)
Sandpaper sheet with a drill or orbital polisher
Also I believe Walmart has a headlight polishing service where they'll do it for you for something like $35. There are people out there that can professionally do it for a lot less than a new set of lights.
ive done it twice in the span of 12 years since owning my car, and it always gives it a fresh look everytime.
thanks
