Radio died when motor mounts changed!
E430
I was replacing the motor mounts in my 1999 E430 when sparks flew. I was unbolting the top of the passenger side motor mount when my wrench touched something forward and I saw sparks. I disconnected the battery and finished the job. When the battery was reconnected I reset the windows & headrests. Everything works fine except the radio is dead. Will not turn on, display is blank. I checked fuses 5 & 11 which are fine. It is the original Mercedes Benz factory radio with a CD changer in the trunk. Are there any other fuses to check? I have ordered the keys to pull the radio and check for 12VDC at the back. Is the 12V input clearly marked?
Thanks!
George
Thanks!
George
98 Brilliant Silver E320 Wagon
The radio has a fuse in the back panel. Be sure to check all fuses with a DVM or continuity tester as visual inspection isn't always accurate.
There is a dual DIN connector on the back of the radio. There are two 12v signals -- one for switched power and one for continuous (memory settings).
Pinouts are available at the Becker NA site.
E430
Richard,
Thanks for the quick reply with useful information.
I had only eyeballed the fuses holding them up to the light.
I just pulled the fuses again and checked with a DMM. Both fuses OK.
Now the radio is working! “CODE” came up, I put in the code and life is good again!
I guess the memory needed another power cycle? Last time, I pulled the fuse under the rear seat reinserted it and then did the same with the fuse under the hood. This time I did the same in the reverse order. Maybe the order of pulling the fuses mattered?
Glad I do not need a new radio!
George
George
