E320 oil leak and repair manual
I have an oil leak on the front of my 97 E320. Any tips on isolating it and repairing it. I also would like to find a repair manual to help me with this problem and any others I might find. I'd like to know what I'm getting into on this leak and now I can't see anything . THANKS for any help. BIG RON
209/W210 Estate /W211 modded by MBENZNL
![Post](https://mbworld.org/forums/images/icons/icon1.gif)
The Oil Leak You are talking about Sounds Like its from The front Cam Cover/headgaskit area!
Clean Off the Motor either Steam Clean or Pressure Washer
Then Inspect The leak after a short drive..the leak inQuestion should be at the Pass side of the Cylinder head at the front corner ...and maybe at the rear of the Cylinder head..
I Have Done LOTS of them..Both the 103/104 They all leak..its just when..
Lots of helpful tips on Mercedesshop.com Check It Out!
You Will Need some special tools like a Pin Puller for the front chain rail... etc..
E 320 Oil Leak
Mark, Thanks for your reply. I tried to check the oil leak more closely, and it seems it is coming from either the front of the engine or the front passenger side. There seems to be some oil on the exhaust manifold between #1 and #2 cylinders which looks like it could be blowing up from underneath the manifold. I haven't had a chance to thoroughly clean the front and side of the engine to better determine the source of the leak. Do you know of any place online where I might find illustrations on how to remove the cam cover? I am hoping it is not a head gasket and since there is a little oil on the front of the engine, it may not be. Any help will be greatly appreciated!
W210,E280 ADVANTGUARDE
E320 OIL LEAK
HI TO YOU ALL.
MARK CUMMINGS can you explain about the oil leak,what the cause is and how to fix it, you said-
I Have Done LOTS of them..Both the 103/104 They all leak..its just when.. what help....
thanks
thanks
Re: E320 OIL LEAK
Originally posted by STEVE 280 UK
HI TO YOU ALL.
thanks
HI TO YOU ALL.
thanks
