Why does the sound from my cd changer sound great but the radio is crap?
Old Mar 6, 2010 | 08:55 PM
guitarplayer's Avatar
2023 GLC 300 4MATIC
Playing through my cd changer the tone is nice and full and deep. However, using the FM, my radio sounds thin, like a freakin transister radio. Why? Is the radio itself to blame?
Old Mar 6, 2010 | 08:59 PM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Coming from my limited knowledge in sonics, I was always under the assumption that radio transmissions had a much steeper cutoff for higher frequencies along with weaker lower frequencies.
I believe the evolution of HD Radio would help if you had an HD Radio ready head unit...and is supposed to be at the level of CD audio.
Jon
Old Mar 6, 2010 | 10:42 PM
tirona's Avatar
1997 s320, 1997 e320
2 things affect the sound quality: 1) signal to noise ratio (snr), 2)frequency response (fr). snr for cd is around 100dB, while for fm tuner is around 60dB, that's why cd sounds better. also cd has better fr than radio, for cd is around 10k Hz, whereas for radio is around 30k Hz.
http://en.wikipedia.org/wiki/Audio_n..._Dynamic_range
http://en.wikipedia.org/wiki/Frequency_response
Old Mar 7, 2010 | 01:40 AM
Figuero's Avatar
2002 E430 4MATIC
Your FM should sound as good as most every other FM radio. It's not CD quality, but it shouldn't be crap either. Try adjusting the treble/bass levels.
Old Mar 7, 2010 | 01:41 AM
Figuero's Avatar
2002 E430 4MATIC
Or...perhaps your antenna has a poor connection......
Old Mar 7, 2010 | 10:24 AM
tmandel's Avatar
'99 E320 4matic Wagon
Are the "Audio" settings independent for each source? Check bass, treble, etc. w/ a CD then w/ radio on.
I don't think this can be the problem, however -- and I don't have this problem. Radio sounds fine (w/in limits of FM frequency response).
Old Mar 7, 2010 | 02:14 PM
01BlackE320's Avatar
01 E320
I noticed that also. The CD quality is dramatically better then the FM radio. Much more noticable then in other cars. I'm used to it now. Some stations do sound better then others though.
