Location of Crank sensor E320 - help
Old Mar 10, 2010 | 04:31 PM
irishman147's Avatar
E320
can someone tell me where the cps is located on the engine. its a 2000 model , thanks
Old Mar 10, 2010 | 06:10 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Look down at the back of the engine on the left (drivers) side below the cylinder head. Black plastic with a wire coming out and a single mounting screw next to it. If you know where the flywheel would be, it is positioned to sense it's motion.
Old Mar 10, 2010 | 06:30 PM
E320
RichardM98...thanks for ur help and knowledge
Old Mar 11, 2010 | 10:22 PM
fdte320's Avatar
DIY sticky at benzworld.org.
Old Mar 12, 2010 | 12:33 AM
E320
thanks for the much needed help
u meet the coolest peoople on here . thanks for ur help
Old Mar 12, 2010 | 12:59 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Easy DIY. It is accessable where Richard says. No need to worry about install as it is plug and play with no adjustment. Good luck.
