Side Marker removal
Old Mar 31, 2010 | 07:30 PM
frabouden's Avatar
GL 320TDI
Side Marker removal
Anyone has experience / expertise in removing the front side markers (without breaking the tabs)? thanks
Old Mar 31, 2010 | 08:29 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
You might want to try posting here:
https://mbworld.org/forums/gl-class-x164-77/
Old Mar 31, 2010 | 08:40 PM
frabouden's Avatar
GL 320TDI
side markers
my mistake - the question was for my 2000 E55 - hence i believe i posted correctly - thanks
Old Mar 31, 2010 | 08:59 PM
RichardM98's Avatar
OK. On the W210 there is a wedge shaped 'pocket' on the inside of the wheel housing (sometimes called the wheel well). It is located near the back edge of the side marker. Easy to see if you turn your front wheels all the way to one side. Just put one/two fingers into the pocket and push on the back of the marker housing.
Old Mar 31, 2010 | 09:34 PM
Javys21's Avatar
01 E320
Be very careful, if it doesn't come off while pushing with your fingers. Then try using a flat head screwdriver pushing gently....It will come off then
